Why does PC Reviver not complete a scan or repair the problems found?
If PC Reviver will not complete a scan of your computer or a specific area, ensure that the area which you want scanned is selected and included in the analysis. To do this, click on the Repair tile from the side menu. Simply click on “Settings” beside Uninstall Cleanup. You can select and deselect each section by clicking in the respective box.
To repair identified errors you need to register and activate PC Reviver. To register PC Reviver you can either click on the Upgrade to Full version at the top of the screen or you will be prompted to register when you try to repair all the problems found.
